The only issue was getting the nut on the back bolt, had to remove the fender flare to gain access through a hole. Watched the install video on youtube first, nice American made part
Now that you've completed the install, couple questions:
Would it be worth it to make some backing plates to sandwich the side body and floor sheet metal?
What about a rubber liner between the side body and the slider?
Watch the video on youtube, it is really neat the way this aligns up and mounts, they welded in some tall spacers that fit perfectly in the existing floor, everything is bolted.
No rubber liner, I was thinking of running a small bead of silicone to keep water from getting behind it
Always a good day when you can hang these up
Installed the new steering stabilizer. Hopefully I will get a chance to install the new adjustable track bar this weekend.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Drove my TJ to work today for the first time in 3 weeks. Didn't want to start like it was starving for fuel.
Replaces fan motor and blower motor resistor.... what a freaking nightmare. If anyone has to do it, buy OEM because you do NOT want to change out a junk offbrand 4 weeks later.
InstalledRancho 5000x in the front and got the 7000 on the rear, flow master 40 series(sounds awesome) Going to do a clutch tomorrow
