I know this subject has been beat to death however since I'm in CA the rules are different than other parts of the country. I didn't mean to hijack another thread so I thought I would ask here instead. I've been enlightened on the process of an engine swap in CA and found that it is indeed easier than I thought. Easier doesn't mean easy but at least there's a path.
My TJ6 is sitting on 40s and has a lot of rolling weight. I really like the set up and it performs really well off road so I really don't want to change that however getting to the trails is pain. Living in SoCal requires me to either drive into the mtns or out to the desert to get to the trails (no tow rig for me). The stock 4.0 is fine on the freeway if it's flat but give me an incline and it's a bear.
So my question is this, do I plan for a swap or do I build a 4.6 stroker? I'm limited in CA for a stroker as well but I understand if I build a 4.6 and it'll pass a smog test without worry. My thought process is this:
4.6 Stroker
Engine swap
I'd love to get your opinions. Again, this isn't just a question regarding a swap vs stroker but specifically due to the hassles built into living in CA.
4.6 Stroker
- Does it give me the horsepower I need?
- Probably cheaper than an engine swap
- What is the true longevity?
- No changes to wiring
Engine swap
- More expensive than a stroker
- Way more hassle with wiring and emissions
- CA CARB approval required
- All the horsepower I need
