I am very familiar with the TJ operating temperature and the position of the needle on the dummy gauge on the dashboard.
My 2003 TJ has a 4.6 L Stroker Golen Engine. The jeep has hood louvers, an aftermarket high-speed electric fan, a 4" long-arm lift kit, and 33" X 12.50 tires.
Once the engine is up to temperature - The "dummy" gauge on the dash is steady "just left" of the 210-degree mark. I have driven it this way for some time without thought or without problems. However, I plugged in an obd2 aftermarket gauge to monitor the temperature- I live in Arizona.
When I am on the highway, in excess of 60 MPH (RPM 2,000 - 2,500) - The OBD2 gauge will climb to and read 226 degrees - However, the dashboard dummy gauge is consistent at just the left of the 210-degree mark. I have no performance issues.
(((If the 4.6 L stroker is running hotter than "normal" - The Golen Engine website recommendation to switch out the -195 for 185 Deg. Thermostat and upgrade to a high-flow water pump.)))
My questions to the community:
Should there be a discrepancy in the OBD2 reading and the dash temp gauge?
Could the OBD2 gauge is a crappy meter?
Is 226 Degrees ok for the 4.6 L stroker engine? Will this temperature harm the engine?
What type of difference will the 185 thermostat and the high-flow water pump make?
Thank you in advance!!!
P.S. - I have contacted Golen Engines with these same questions.
