Lift Build Plan Review
Thanks - I stumbled upon a thread @Jerry Bransford was on and he was really liking the Savvy lift ride quality even over his OME lift, but I wasn't sure if only doing their tuned Fox shocks\springs would net comparable results since its not a complete $2500 kit Savvy kit.
I think @Jerry Bransford is running the Rancho RS5000X shocks, so maybe a good compromise to save some caps?
Reactions: FTI76
I've read a lot of good things about the Rancho shocks as well. I know the OME lift is well regarded but if I can piece something together for comparable cost that is better I am happy to do that.
Reactions: bobthetj03
I don't think you could go wrong with Savvy's 3" springs and the RS5000X's. You can buy a rear TB relocation bracket from anyone. Only unknown will be if the MML will be enough to eliminate drive line vibes. May have to drop the skid a bit if you get vibes.
Most people seem to do just fine with a 1 inch MML and 1 inch BL and I will be doing both.
I ordered the Savvy 1.25 BL today on lunch it was $124 on 4LowParts
You can't go wrong with anything Savvy or Currie. That's a fact.
OK so my build list is complete. I made some tweaks from original list.
Remaining parts are being ordered and I should have this done within the next few weeks.
  1. Savvy 1.25 Inch BL
  2. Iron Rock Offroad 1 Inch MML
  3. JKS adjustable track bar
  4. Currie Correctlync steering
  5. OME 2 inch lift with HD springs\OME steering stabilizer
  6. Lower Metalcloak Adjustable Control Arms
  7. 33X12.5R15s Cooper STT Pros
  8. Mammoth Type88 15x8 Wheels
You're going all the way at once. I can't wait to see it. Sounds similar to what I'm aiming for
Reactions: Rob5589 and FTI76
I feel really good about this list. I've come a long way from just buying the Zone 4.25 combo kit. Lot's of research and listening to people with experience. But at the end of the day everybody has their input and you just need to make an informed decision with cost as part of the equation. Down the road I will look into axle\re-gear options and maybe a tummy tuck which the MML\BL sets me up for.
Sounds like a great setup, you'll be really happy with all of those parts. The OME lift in particular is fantastic, I loved the way mine rode. Not to mention that at that lift height, you're not going to have to worry about spending the amount of money you would with 4" or more. That cost me a lot more than I anticipated it would!
Reactions: FTI76
With the MML and BL do you need a SYE and DS now? Or can you get by with a TC drop?
You won't be far from a TT. It sounds great what you're planning. That it's coming soon is all the better. Given me some ideas too. Thanks!
Will the Currie Correctlink steering play nice with a 2" lift?
Currie recommends 2" or more of lift. It should play nicely at 2" I believe. The worse case scenario is you might have to add some more bump stop I believe.
I think the only issue with it is the JJ end coming close to the diff, but if he keeps his CA length stock, 1" bumps should keep it clear.
