How did this project turn out?
I thought about it overnight and I can give a more helpful answer.
I started this whole process because of a big dead spot in my steering which made it difficult to drive.
#1: I started with the toe. I made a version of the alignment tool and measured my toe at 5/16". I found ORO's guidance for the U Turn steering and it said 0-1/16" was appropriate. I set to 1/8". The dead spot was reduced quite a bit but the jeep became even more of a handful. It seemed that the road wanted to steer the jeep everywhere.
#2: I removed the U Turn crossover steering and replaced it with the Currie Currectlync because the U Turn had the reputation for having a large dead spot in the steering. There was improvement in steering responsiveness and reduced "road steering" but is wasn't sufficient to say it was "solved."
#3: BuildBreakRepeat asked me to post pictures of the front end. Blaine and he immediately identified the drop adapter for the track bar as a big source of bump steer (I wasn't even aware I had a drop adapter). I replaced the RockKrawler track bar with the Currie JJ track bar. On road steering was better for bigger bumps but the jeep still seemed to wander as much.
#4: There was a lot of play in the steering shaft (15-20+ degrees) into the ZF steering box. Time to install the PSC gear box, pump, and reservoir. This was a direction I wanted to go anyway because of 35" tires and the lockers. In all, the steering shaft play seems now to be reduced by about half but it is not zero.
#5: I took off the steering stabilizer.
My steering right now is dramatically improved but not as good as I would like. A) The steering sensitivity is very good--my dead spot is gone. If I turn the wheel at all I can feel the front tires responding. B) the jeep no longer wants to leap across the lane if there's a groove or edge that I encounter. While the bump steer is much reduced, I can still feel it occasionally. C) It wanders less but it still wanders. It's easier to manage but I'd like it to quit wandering.
Next I'm going to the knuckles, ball joints, etc. I installed the Synergy ball joints quite awhile ago (when they were fairly new). I can't see any inordinate play but it may be a source. In any case, I think the 15/16" brake/knuckle kit from BMB is likely. I'm out of ideas after that.
