Oil pressure sender with different year engine
Tarmijo94
Arlington, TX
Hello all,
I know that there are hundreds of questions about the faulty oil pressure sender on our TJs, but i cant find one quite like mine.
I have a 97 with the 4.0. When i first bought it, it did the familiar drop to zero when the engine was warm/highway miles. Then turns out when i bought it, the coolant leak was not a head gasket, but a cracked block.
So long story short, i have an 04 block in it now. The gauge still does the drop to zero after warm.
So my question is, do i buy the sender unit for a 97 to match the computer, or an 04 to match the block?
Any help is appreciated, I've kinda just written it off for awhile as I wasn't driving it much due to gears, axle upgrades, tires, blah blah blah, and the level was good and all sounds were normal from the engine
When you replace it. Make sure you use some electrical contact cleaner to thourougly clean the harness before reconnecting it to the new sensor. It is usually full of oil, dirt and grime.
Reactions: Tarmijo94
Received the part today, My 97 does not use the same part number as 98. 56031003 and 1005 have different connector pins, even though the body is the same.
oh man, that sucks. Sorry about that. My goal when I put the table together was to figure out what I needed for my 99 TJ's. Once I figured that out, I left it alone. Funny that no one else has said anything about it in months.
Once you get it figured out, let's update the spreadsheet so others can avoid the trouble
Well i did what i wasnt supposed to and bought the Crown brand sensor, as i had marred up the old one removing it, and now didn't have one at all. so far its been okay with the check gauges. Bought the one ending in 1003, and it plugged right in.
While calling around, a couple dealerships confirmed that 1003AB if for the 97
