I have a 2004 LJ and have replaced the rear taillight incandescent bulbs with LED bulbs. Of course they are hyper flashing, indicating the CPU thinks the bulbs are out due to the low current draw. There are only three wires coming from the light fixture, VT/BK (Backup Lamp), BK/YL (Tail Lamp), and DG/RD (Left Turn Signal). There is no ground wire near the housing as the ground connection is made via the screws to the body that secure the light assembly to the vehicle.
How do I wire a Pilot Load Resistor in parallel with vampire clamps to the circuit with no ground wire? I think I have a couple of options, but need verification.
1. Clamp one end of the load wire to the DG/BK wire and attach the other end to one of the body mount bolts.
2. Run a new wire from the chassis ground up to each tail light assembly and splice the ground connection to one end of the load and calmp the other end of the load to the DG/BK wire.
3. Clamp the load between the DG/BK (Turn) and the BK/YL (Tail) wires.
If someone has run against this issue, please assist in helping me figure it out. I appreciate any comments. I will add photos of the wires and schematics later.
