I recently installed a PSC pump, gearbox, and Blaine's bolt on cylinder assist kit.
The first pump was noisier than stock, and could easily be heard at idle in the cabin, mainly as a low growl. It occasionally made noise at higher RPMs. I called PSC and they sent me a replacement.
The new pump makes the same low growl, but as the engine hits 3200 RPM, it begins to scream. It sounds like I have a supercharger. I called PSC and they agreed to replace that one right away.
I have tried re-bleeding several times, making sure no air bubbles appeared in the reservoir on the final bleeds. I orginally had the reservoir mounted in the PSC bracket on the brake booster. I have since relocated it to the fender immediately adjacent to the PS pump. I am running -12AN feed and -8AN return lines. The relocation and shortening of the lines made zero difference. I tried covering the fittings in oil while it was screaming to see if they may have been sucking air, but there was no change in noise.
How loud are these CBR pumps normally? I'm guessing they shouldn't scream, but is a constant growl at idle normal? Similar to a loud A/C compressor?
