AiROCK™
WHAT IS AiROCK
AiROCK™ is a computerized suspension system that provides the ultimate in control, both on and off road.
When driving on-road AiROCK™ provides a smoother ride and allows limited adjustments at a lower ride height. It constantly monitors ride height and automatically compensates for any body lean that occurs. By maintaining a lower center of gravity it provides improved handling and reduces the possibility of a roll over. These improvements allow a vehicle with very large tires to be used as a daily driver.
When driving off-road AiROCK™ provides complete manual control of the suspension. It allows the vehicle’s center of gravity to be altered by shifting it in any direction. The controls easily allow modification of approach and departure angles along with ride height.
In either mode the height and ground clearance is maintained independent of vehicle load. The system also has an optional “egress” setting to lower the vehicle when the ignition is switched off, making getting in and out easier and more safe.
WHY DO I NEED IT
Air springs articulate more naturally than coils making driving off of rocks less jarring and off camber situations more stable.
When changing to different sized tires, simply adjust the ride height from inside the cab instead of swapping out coils.
For off camber maneuvers you can lean the vehicle into the hill, and lower it to keep the center of gravity down.
Tired of hitting your bumper on tall rocks you’re trying to climb? Just tilt back or raise the vehicle to provide clearance for your bumper.
If you get high centered, simply raise the vehicle up and continue down the trail.
There are countless other situations that AiROCK™ systems make more safe and enjoyable.
COMPONENTS
AiROCK™ is a computer controlled system that replaces the coils with air springs. The bump stops are moved to the custom shock absorbers that come with the kit. The system includes:
- The user Control Interface.
- The AiROCK™ Control Unit (ACU).
- Four air springs.
- Four custom shocks.
- Four height sensors with stainless steel brackets.
- The wiring harness.
- Air line and fittings.
All of the parts in this kit are warrantied for one full year from the date of purchase.
The Control Interface consists of a display and six control buttons, encased in black anodized aluminum to ensure longevity and a clean OEM appearance. Its backlit display varies its brightness automatically with changes in daylight.
The ACU ties into the Vehicle Speed Sensor to constantly monitor the vehicle speed. It controls and monitors the pressure in the air springs and air supply along with monitoring the height sensors. This information not only allows AiROCK™ to operate in two different driving modes, off-road and on-road, but also to detect and diagnose any problems that might occur in the system.
OPERATION
AiROCK™ allows user control of the vehicle’s center of gravity by making height and/or tilt adjustments at the touch of a button. A simple, intuitive dash-mounted user Control Interface provides a powerful way of adjusting the vehicle’s suspension in real time.
The user Control Interface has four directional arrow buttons, a “check mark” button, and an “X” button.
- Push the left or right arrow button to tilt the vehicle left or right.
- Push the up or down arrow to tilt the vehicle forward or back.
- Push the left or right with an up or down button to tilt the vehicle diagonally toward the specified direction.
- Push the “check mark” button to automatically return to your preset off-road or on-road ride height.
- Push the “check mark” button with an up or down button to raise or lower the vehicle.
The functionality of the arrow buttons can be configured to be momentary or latching (automatic). When configured as momentary the adjustment occurs only as long as the button is held. When configured as latching the adjustment automatically continues to the full extent. Latched automatic adjustments can be immediately stopped by pressing the “X” button. The six buttons are also used to access and navigate the menus to initialize and configure AiROCK™.
TJ REQUIREMENTS
AiROCK™ is a coil replacement system but not a complete suspension lift kit. We offer both 4″ and 6″ AiROCK™ bolt-on kits for Jeep® Wrangler™ TJs.
If you do not already have a lift installed, we highly recommend using the Rubicon Express Extreme Duty Long Arm lift kit with the AiROCK™ 6″ system. As with any significant lift, the changes the drive line geometry to accommodate AiROCK™ must be addressed. A Slip Yoke Eliminator and rear CV Drive Shaft need to be installed in order to handle the extreme axle travel that the AiROCK™ system provides.
The AiROCK™ system also requires a clean supply of pressurized air from an on-board air (OBA) system. Some TJ owners already have an OBA system, which is why one is not included in the AiROCK™ kit. We do offer a separate OBA kit designed specifically for TJs. See our Complete Air Kit page for details. We also stock most of the fittings and accessories needed when piecing together your own OBA setup. Click here to see OBA kits and components in our store.
Here is a summary of the prerequisite components for installing AiROCK™ on a TJ:
For the 4″ AiROCK:
Slip yoke eliminator | CV drive shaft (rear) | Adjustable track bars* | Adjustable upper arms (rear)* | On-board air system
For the 6″ AiROCK™
Slip yoke eliminator | CV drive shaft (rear) | Long arm kit | Adjustable track bars* | Adjustable upper arms (rear)* | On-board air system
The following video clip displays our TJ with 6″ AIROCK kit, 1.25″ body lift and 35″ tires at the range of heights the AiROCK uses as presets.
