ToddDerrArtist
Thanks for the link. That looks easy enough to make.There’s this, Quadratec dome light switch.
I made my own version of it with parts I had on hand already.
Yah, when I hit a different bump on my way home, that would sometimes kind of make the Jeep jump over a bit, it didn't do anything per say. It just hit the bump and kept going, no wobble.
I will double check the torque on things tomorrow, just to rule that out.
Not today, but over the last week,
Pulled the interior
Got the sound proofing down (that's an awful lot of rolling....)
While I had the console out, I went ahead and installed and wired up the trans temp gauge:
And then today, my SAVVY arms came back from powder coat, we got lucky they match the patriot blue almost perfect. It's a shame they will be buried under the TJ...
Does it have a feature to lock the throttle in like the others? Or does it require you to keep constant tension on it?Trying out a new style hand throttle using a small cycle lever. I will finish and test drive this weekend.View attachment 160703.
Constant tension. Your finger runs it like your foot. It is a stubby and fits right under the hand. I will finish and drive it and see what it feels like.Does it have a feature to lock the throttle in like the others? Or does it require you to keep constant tension on it?
Oil pan is one of the upgrades I want to do next. Wishing Moroso units weren't so expensive though. Stock NOS it is
Perhaps you can answer this question, since I'm reading conflicting information elsewhere.
Does the Mopar oil pan have a baffle in it or not?
Package arrived with some mirrors so I can take my doors off. I need to find a better solution to my dome light vs pulling the fuse. I'm sure y'all know of something.
Misty Midnight:Very nice, did they use a prismatic powder color?
Instead of pulling the fuse, I used a fuse tap to add a switch to the fuse. I located the switch up under the dash next to the passenger courtesy light. ($4 for the switch, and $7 for 10 of the fuse taps on Amazon.)Package arrived with some mirrors so I can take my doors off. I need to find a better solution to my dome light vs pulling the fuse. I'm sure y'all know of something.
Made a drive up the Ocoee Gorge(pavement) to the pulloff for Goforth Creek. It's a short hike along a beautiful shade filled tributary full of sweet cascades and waterfalls. Got in one quick painting today.
Waiting on the rest of my parts to replace hoses and such on the cooling system. Not had any issues, but 100,000+ mile maintenance. I'm trying to not be like my dad (God love'm) and wait until something breaks to fix it. New jounce bumpers on the replace list too, since they are nonexistent on my Jeep right now. Eventually new springs and shocks. I've had good luck with BDS in the past with my XJ. Just going 2" max....I know, that's what we all say.
Here are my painting picks from today.
Here's a little video I put together:
That was done at least 11 or 12 years ago.Trying out a new style hand throttle using a small cycle lever. I will finish and test drive this weekend.View attachment 160703.
Ok, power went out at both houses so what better thing to do but tell hubby I want to check the torque on the track bar. Needless to say, I think I found the problem. He put it on with the impact wrench but never checked the torque. When he took a wrench to the nut, the bolt and nut spun inside the hole. LOL He took a torque wrench to it and probably cranked it about 3 to 4 times before it actually did it's thing. It is now at the 110 ft lbs, the instructions call for. Will drive it and let you all know how it goes tomorrow after work.
Uhgg, hubby's that want to take short cuts. LOL
I see that part of the belt came off and wrapped around the fan. Did the motor seize up?
