Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
There's just something about new sneakers....
those look a great wheeling tire, will you be driving on the road much? They look like they would be pretty bad on street.There's just something about new sneakers....
View attachment 161113View attachment 161114
No this is mainly a trail Jeep and won't see hardly any street time. I'd guess a 80/20 split. It'll be trailered most of the time also.
The IROCK tires are not a bad street tire either but from what I have heard you'd only see about 30K out of them.
33!? CmonnnnnI LOVE Iroks! They are not bad at all on the street, in fact much better balance than TSL’s.
but you are correct, they are a soft tire. I should have bought them. Next time, when I go up in size. Damnit, gotta stop watching these builds, I was dead set on 33’s tops!
what are you doing with the rocker knockers?
33!? Cmonnnnn![]()
Honestly 33s are awesome and 35s require a ton of compromises. If you’re not limited by that size on the trail, then there is no reason to go upBeen down this road so much, I made a promise to stop at a rather mild build. But...since I have a 4” lift and added the Savvy BL lift, I’m ready for the next step. Ugh. Just don’t want to drop the 10k.....
Honestly 33s are awesome and 35s require a ton of compromises. If you’re not limited by that size on the trail, then there is no reason to go up![]()
The rocker knockers will be going on the daughter's TJ with all the other stuff coming off my TJ.
I have the old genright sliders that weigh 120lbs...need those savvy’sNice! She’s getting some great parts! I really want to change mine out for Savvy’s too, love the design!
Those are some badass tires. I haven't read through the thread so you may have already covered this but they must be pretty pricey with such an uncommon size? I actually changed rim size on my Tundra because the NItto Trail Grappler's were so expensive at the size I wanted.
In my world, I can't deal with the 2 positions of the steering wheel. My steering is far too important to me and my OCD to live with it off-center on the trail or on the road which ever your poison may be.What is it about the AiRock that is the problem as you see it?
Not with that wheelbase or some serious shock travel compromise.Can you driveshaft handle 14” shock in the rear at droop?
So what would be a reasonable amount of travel for my WB?
Bolt in your driveshaft and check what angle it binds. Move the axle up slightly so it doesn't bind. That is your limit for down travel.
