I've looked into the Timbren before.
Pay attention to the lift height on each model. Not only are there half a dozen weight ratings, each one can be bought with various height lift or drop spindles. Most are available in straight spindle, 4" drop, or 4" lift.
If you're considering the 2000 lb model, consider the 1 Tonne (2200 lbs) model instead. The 1 Tonne model is the 3500 lbs model with a longer trailing arm, giving it the most suspension travel (and probably the softest ride) of any of their kits.
Be sure to look up the actual heights of the models, as well as the deflection under load. Some models lose as much as 3.5" of lift under full load.
The models denoted as "HD" are models that are based on heavier duty weight ratings with softer springs. Don't buy a kit that significantly exceeds the weight rating of the trailer. Instead look for an HD model if you want extra beef. For example, the 2000HD is the 3500 lbs model with a softer spring. I believe the 3500HD, 5200, and 7000 lb models are all the same units with different springs.
These kits are designed to be used with non brakes or with brakes spindles. Consider adding electric drum brakes at the same time. They can also be fitted with disc brakes.
A lot of off-road trailer manufacturers routinely use these with 33 or 35 inch tires. If you want to fit a large tire like this, get a kit that uses a heavier duty spindle. For example, the 1 Tonne and 2000HD models use a 3500 lbs spindle, which should be fine for 35s with the reduced weight rating.
A 3500 lbs trailer hub has the exact same wheel pattern as a TJ. So you can use the same wheels and tires on your TJ and your trailer.
Certain models are also offered with longer spindles that place the WMS further out. If you want to mount a wide tire like the ones you have on the Jeep, consider these ones.
You may need to beef up the frame of the trailer to take the extra stress of the axle-less. If in doubt, install the crossbar called out in the instructions. The crossbar sits much higher than a normal axle, so you wont lose much clearance. You may also want to sister the main rails with some heavy wall angle for a good length of the trailer.
Be sure to check out the attached PDF which has all of these variables listed.
