Blaine has done this enough times he immediately caught my screwup.
Has zero to do with how many frames I've cut. I'm a carpenter. I mark lines on stuff and cut on the line. Doesn't matter if it is lumber, plywood, plastic panels, sheet metal, square tube, or what, if you make the line and don't cut on the line, the dimensions will be off.
"Cut on the line" is also relative. Some folks take the line, I cut right at the edge of it or strive to. You have to do what works for you and trust me, there are many interpretations of what cut on the line means to folks.
It is also very hard to teach for some reason. It isn't a hard concept but the execution seems difficult for lots of folks. Also why I use a scribe line from something like an ice pick. That line is easy to see against the black frame paint and if you walk the cut from one side of the line to the other, it is still a good cut. Walk the cut from one side to the other of a Sharpie mark or china marker line, and the cut is out of square by 1/8". As the diagram shows, each arrow points to a 1/8" gap which is now 1/4".
You can also use a china marker or 1" wide Sharpie if you keep the cut exactly at the edge of it. I have found that most can not do that. The line width is their variable. As long as they stay within the two edges, they are good.
