If you need a good person to redo the gears. Two of my jeeps and several friends have used Shawn at River City Diffrentials in Rancho outside of Sac he has been outstanding. Even helped me a bunch when I regeared my XJ myself.
I’m afraid to tell you what my rear driveshaft angle is.Here's my thinking. Raising the pinion angle decreases the ds operating angle. This is my theory as to why I think the next step, after sorting out the re-gear fiasco, is to lower the t-case skid.
I tend to believe there is something other than DS angle going on because I'd bet @JMT's with the Savvy tuck and NP231 is higher as well. Along with many others.I’m afraid to tell you what my rear driveshaft angle is.
I agree, I used to have a harmonic that started about 75 but nothing down lower, it’s gone now but so many things are different and new.I tend to believe there is something other than DS angle going on because I'd bet @JMT's with the Savvy tuck and NP231 is higher as well. Along with many others.
My TCase is WAAAYYYYY up there. Pinion is 18*/driveshaft is 20*. I was up to 84mph the other day, vibe free.I tend to believe there is something other than DS angle going on because I'd bet @JMT's with the Savvy tuck and NP231 is higher as well. Along with many others.
I'd think if it was in the transmission the vib would also be present when the rear shaft is removed. Makes me lean towards T-case. @bobthetj03 I'll let you know what TW says tomorrow about spline contact in the rear shaft when I discuss it with them.I think the driveshaft angles can be ruled out at this point as well. Considering the vibration happened directly after a regear initially, I think the only issues could be between the output shaft of the transmission and the output shaft of the transfer case. Since the diff has been rebuilt multiple times and the driveshaft has been swapped as well, i think it really has to be in that area.
I think the transmission is unlikely, but considering the transfer case has been rebuilt as well, maybe I’m wrong.
Going back to Sacramento this coming Monday for the gears?
Hope so to! Oh!....and stay away from the scotch this time.Yep. Hoping they make good.
What day are you going to pick it upIt's gonna be a turn-n-burn, so no scotch LR. Leaving it with them for the week.
@Indy go steal his jeep once it's done and let's swap out the t-case. Worse case @bobthetj03 could report it stolen or go park it in downtown Sac overnight.Hey @Starrs , do you think a 03-04 Rubi can be found for under $12K? Mileage isn't a concern. Bone stock is a must.
Edit to add: 5 speed and AC. Don't care what top it has.
