Here we go @Northwood, it's at least stubbed out. Let me get on my pc at home so all the resources are at the ready!
That is the preferred way to do that, but it involves one more die, a generic de-priming die. That's what I do. I also run a primer pocket cleaning tool into the primer pocket to get all the hardened scunge out. Well, it's actually the the uniformer, with the cutting edges on it. It's the only thing I've found that gets all the corruption out of the primer pocket.I would suggest de-priming the brass before cleaning if you are going to use liquid cleaner, it will help clean the primer pockets also.
This really isn't as big a concern with pistols as it is when reloading rifle cartridges.
Also, make sure the brass is completely dry before charging them with powder. (brought to you by Capt'n obvious!)
Isn't it though? Going through and prepping new brass for the first time is a time consuming thing. Needs to be done though if you want that last little bit of accuracy. Surprising how little is required for generic blasting ammo. For my 45 ACP blasting ammo, I don't even polish it any more. Just inspect it, wipe it off and load it. Mixed cases and all...Actually, I was assuming you were using the three die sets. Brass prepping is the most tedious part of reloading. I realize you are keeping it on the smaller scale here, but after years of using the hand primer pocket tool, I finally bought one of those prep stations that holds 5 tips and they all turn at the same time.
Mine are all securely mounted to a bench.Wow, awesome info so far.
So, @StG58 or anyone with experience, do any of you actually use and enjoy a portable press? The more I think about it the whole portable thing seems to look more like a pain in the ass than any sort of advantage. I dont see myself doing any of this without a solid working space, which would mean a work bench of some sort, so maybe a bench mount makes a lot more sense?
He was indeed, per my request. Just second guessing myself now that i look into it more and more. That is a very good point i hadnt thought about that benefit to itMine are all securely mounted to a bench.
The portable ones would be good to take to a range if you wanted to work up a load one by one to find out what works best in your gun. Then you could go home and crank out a shit ton on your turret or progressive press.
But I think StG58 was trying to keep it simple and space saving for those who may not have room for a bench.
Yup, for the very reason that @egclassic stated. Load development at the range. I have done some loading in the field, just for giggles and to prove it could be done. Once or twice I've done the whole cycle...shoot, dig the bullets out of the berm, cast, reload, shoot. A muzzle stuffer is vastly better if you want to do that though.Wow, awesome info so far.
Now that doesn't sound half bad! I saw something of the sort by Lee but it didn't have much work space. Essentially just a portable mount for your pressA portable reloading bench is a good compromise.
I suppose that and a good chunk of wood would make something that could work out pretty wellThere's better, cheaper ways to go about it. Craftsman, and others, make a portable work bench that folds up nicely, almost like a super duty saw horse. Those make a good base.
I wouldn't put a Dillon 1050 on it, but they are pretty nice.
