Alright so Saturday I pulled in the garage to put some gauges on my 02 TJ 4.0. Removing the oil pressor sensor sit broke and tried to run it without and it would not fire. It cranks but will not start. Ok so I said screw the gauge and ordered a brand new oil pressure sensor and installed today and same issue it will crank over but will not start. Please note I drove it all day and pulled it in the garage no issues. Now I have checked fuses swapped fuses relays and checked everything to make sure I did not knock anything loose. Today I ordered camshaft position sensor to try that next and see. I also bought a code reader and it keeps saying will not connect please try this this and this but nothing works. The key trick shows nothing for codes just mileage. Battery is brand new and reads perfect tested today. Like I said it cranks just will not fire. Any input what am I missing why did or how could this just randomly happen after I messed with the oil pressure sensor? Do I need special tools to check if I am getting fuel. I did starter fluid nothing it’s like maybe something is not allowing something. How do you check spark on fuel rails? Please guys any help? @Jerry Bransford
