TJ cranks but will not start
Milrz
SWFL
Alright so Saturday I pulled in the garage to put some gauges on my 02 TJ 4.0. Removing the oil pressor sensor sit broke and tried to run it without and it would not fire. It cranks but will not start. Ok so I said screw the gauge and ordered a brand new oil pressure sensor and installed today and same issue it will crank over but will not start. Please note I drove it all day and pulled it in the garage no issues. Now I have checked fuses swapped fuses relays and checked everything to make sure I did not knock anything loose. Today I ordered camshaft position sensor to try that next and see. I also bought a code reader and it keeps saying will not connect please try this this and this but nothing works. The key trick shows nothing for codes just mileage. Battery is brand new and reads perfect tested today. Like I said it cranks just will not fire. Any input what am I missing why did or how could this just randomly happen after I messed with the oil pressure sensor? Do I need special tools to check if I am getting fuel. I did starter fluid nothing it’s like maybe something is not allowing something. How do you check spark on fuel rails? Please guys any help? @Jerry Bransford
You said this:
Any input what am I missing why did or how could this just randomly happen after I messed with the oil position sensor? Do I need special tools to check if I am getting fuel. I did starter fluid nothing it’s like maybe something is not allowing something. How do you check spark on fuel rails? Please guys any help? @Jerry Bransford
You said this:
I’ll fix the three times before I mentioned the correct part I must of auto corrected
They like to dish it out. Don't worry, I'm sure someone on here will be able to help (y)
No I was not doing it on purpose.
I just cannot comprehend the paragraphs he created.
Maybe you can re-phrase it and re-explain it to us so we can help.
IMO - I think he needs to look at the CPS because "not starting" has nothing to do with "fuse" and/or the "oil" and/or related "pressure" low compression issues. It is more of the "fuel" rather than the "oil" is required to fire up an engine. If the battery is new, it could be the alternator problem. He said he already drove it and so spark plugs are not the problem.
Last but not the least, you guys are the ones needing help - why do you treat us (readers) like that? You did not even apologize about anything and you fired up post #7 - a bit of arrogance huh?
To both of you (Thom & Milrz) who are still NEW to this forum - we are friendly here and we know and helped each other for a long long time now.
Reactions: thomat65
@TJ2 No worries. Here's how it reads to me. @Milrz is the following correct?
Alright so on Saturday I pulled into the garage to put some gauges on my 02 TJ 4.0. I broke the oil pressure sensor while removing it. I tried to run without it but it would not fire. It cranks but will not start. Ok, so I said screw the gauges I was going to put on. I ordered a brand new oil pressure sensor and installed it today but it still has the same issue--it will crank over but will not start.
Please note I drove it all day and pulled it into the garage with no issues.
Now I have checked fuses, swapped fuses and relays, and checked everything to make sure I did not knock anything loose. Today I ordered a camshaft position sensor to try that next. I also bought a code reader and it keeps saying it will not connect, to please try this, this, and this, but nothing works. The key trick shows nothing for codes, just mileage. The battery is brand new and reads perfect; I tested it today. Like I said it cranks just, it will not fire.
Any input? What am I missing? Why did or how could this just randomly happen after I messed with the oil pressure sensor? Do I need special tools to check if I am getting fuel? I tried using starter fluid to help start it--nothing. It’s like maybe something is not allowing something. How do you check the spark on fuel rails? Please guys, any help?
@Milrz You'll have to explain what you meant by "check the spark on fuel rails". I think that's another place where you lost people and started getting ragged on. Also don't miss @TJ2 's advice in the post prior to this.
Sorry I jumped on your case (by saying "don't worry someone around here will help" implying you weren't). The first time I read this thread it really did sound like you were razzing OP and that it didn't go over well. So I tried smoothing things over which only backfired lol.
Rereading this thread I can now see the razzing only happened after #7.
So yeah, @Milrz try rereading the thread again like I just did without assuming @TJ2 was egging you on. You may have come on a little strong in post #7. No worries though! It's really frustrating when stuff breaks and it only ever breaks when you most need it working or have other things to get done.
I was asking how you check spark on the coil pack. Can you explain how to check to see if I am getting spark?
You know they pissed me off a little bit that is why I did not answer back. I was waiting for Jerry to pitch in if he understood what kind of help they need.
It’s all good issue is you knew what we were asking. You also instead of offering help or questioning the issue offered a smart ass answer. So sorry for pissing you off but it was self lead.
Reactions: JDS123
Pull one of them - just one at a time.
Get someone to start the jeep while you hold the spark plug (assembled with the coil rubber socket) spark plug tip pointing into the metal part of the engine.
Watch the tip of the plug - it will spark if current goes through when the engine turns. If that works go onto the next - the same procedure. What you are doing here is "process of elimination".
I am new frustrated and came here simply asking for help. Figured if I typed something wrong or worded it wrong I would be asked or assumed a response. In other words I got two smart asses the wanted to make fun of it. I apologize if my grammar or auto correct made a fool of me but honestly we knew what I was asking or could of simply asked for clarification
You'll get the help, I promise. There are a ton of people on here with tons of experience. But amping up the emotions has never ended well on any thread I've seen :)
