Bestop Supertop fitment question
Vidar
Pennsylvania
Ran across a local CL post for a new in box bestop super top for an 03-06, model 51719. I have a 97, anyone know why it won’t fit, or if there is anyway to adapt it? Price is exceptional, and my factory header is rotted so I need a replacement anyway.
The only difference I know of is that the LJs were produced from '04 to '06.
Otherwise, I don't think it matters.
It’s not an LJ top. The info I could find about them was that Bestop produced two distinct versions, 97-02 and 03-06. But they are discontinued now, so I can’t find any specifics. Was hoping someone on the forum know the reasoning did the two different versions.
I have an '03 with the Supertop. Have not installed it yet, I was missing the door surrounds. Just got those so I'll probably be pulling the hardtop and putting the soft on next weekend.
I believe the difference is the 97-02 used the factory mounts, and the 03-06 had a new type of frame. Instead of the attaching to the sides of the roll bar it has a bracket that bolts onto the top of the tub, in one of the holes the hardtop bolts use.
I could be wrong though, I didn't even know what I had until I researched it a bit, still not 100% sure it will work on mine. If nobody else has any solid info I'll post again once I try to put it on.
IIRC the only differences between 2002/older and 2003/newer are the widths of the front latches and the directions the zippers pull.
Thanks for the feedback everyone.
@Jerry Bransford, do you know if the front latches are comparable if they are a different width? I'm not worried about zipper direction, just want to make sure it fits.
Here’s hoping it fits properly. Going to pick it up tomorrow. Brand new with the frame and all hardware, for $260. Apparently he bought the clear windows for his wife’s Jeep, but she wanted tinted so they bought another one and left this one in the box for years.
Dang, if it doesn't work out let me know, that's a great price for new in box and my top isn't in the best of shape. I bet it'll fit just fine though, nice score.
Yes it is. My top is actually in great shape, but my header is rotted out. So it was either pay $105 for a new header, or take this deal that includes a new top too! Hopefully this one lasts longer than my cheaply tops.
Should fit without problem. I have an OEM 2006 Sunrider that fits my 2000 just fine.
Thanks for the confirmation. Hopefully it’s just the zipper direction like @Jerry Bransford said. Considering I’m already on my second 3rd party cheap too, I couldn’t even tell you which part the zippers are on.
Update. They are not interchangeable. The latches on the header do not fit my windshield. Anyone want to buy a brand new Supertop for 03-06?
Oh no, mine fit ok. Can't you just grind off just a bit of the width to make it fit as I believe I did?
@Jerry Bransford, It’s not a width thing. They don’t extend down far enough.
I had a soft top from the factory. Do I need to remove the seal from the top of the windshield to install this top?
I'd grind the top of the slot just enough to let the hooks engage. There'd be enough left so that wouldn't cause a problem and it would only take a couple minutes to grind and file it smooth.
To follow up, I decided to throw in the towel and cut my losses. I didn’t really feel like cutting into my windshield frame. Had another forum member reach out to me that not only has a 2003, but also only lives about 20 minutes from me! He’s going to have a brand new Sunrider top, and I’ll get looking for a replacement header for my existing top. Win some lose some, at least I’m not out any money for this experiment. Man would my wife have killed me if I wouldn’t have been able to sell it.
