Sorry for the delay, I only get to the forum once a day, and only one response per day.
So to go back a few pages...
When Blaine is setting up a new vehicle he is building he said he weighs the corners, then orders the lightest spring rate and to achieve his desired ride height (or something close to that).
Why? If spring rate makes no difference why do this? And to claim a lower rate spring will effect ride height is pure nonsense. Ride height on ANY rate spring can be changed (WHEN THEY ARE BEING MADE) as Blaine alluded to.
And to repeat what I have been saying even before this post started, the suspension is a set of different parts WORKING TOGETHER. And once again for the folks in the balcony, shocks do 1 thing. They control the movement of the spring. They can make a softer spring 'act' firmer, but can NOT make a spring 'act' softer. No shock will make (or 'let's if you prefer) a spring move more than the spring, effected by the combination of road surface and vehicle weight, is designed to. A shock CAN make (and does, after all that is what it is designed to do) a spring act or feel firmer by restricting the movement of the spring.
Using the illustration of Blaine's pickup, which was irrelevant when I used it, no shock will make the truck ride smoother when empty. Sure, a different shock to the one currently being used could improve the ride, but it can't make the spring MORE compliant or move more than the spring would move with NO shock. Yes, that will let the spring bounce uncontrolled (because the job of the shock is to control the spring).
The only way to make a harder spring more responsive to road surface is to increase vehicle weight, so the spring is now working with its correct load.
After the correct spring is selected, that is to say the correct (lowest) rate for the vehicle's weight, and made to provide the chosen ride height, which is done by adding or subtracting coils WHEN THE SPRING IS MADE, now the shock is chosen to provide correct spring control and be the proper length, AGAIN WHEN THE SHOCK IS MADE. Now fine tuning of the shock valving can be done to produce the best travel and spring control possible. This can not be don on a cheap shock produced in bulk. Just as the ideal spring for a specific vehicle needs to be made, not just a spring made in bulk. But to claim changing spring rate changes ride height is to claim that a 4" lift spring can not be cut to produce a lower ride height. It is a matter of how the spring was designed when made. Changing vehicle weight changes ride height, yet spring rate remains unchanged.
This is why I constantly state 'all other things being unchanged. Every company that sells a lift 'kit in a box' has to make assumptions as to the typical weight and use of the vehicle their kit is designed for. FINAL tuning of a suspension is done by changing or adjusting the shock's movement range and valving. It is the easiest and cheapest way to tune each individual vehicle after proper choices are made in tires, tire pressure, spring rate, spring static height, axle location, arm design, etc. It is a complex interaction between multiple components that affect each other in different ways to produce a vehicle that rides and handles the way that person desires.
