Running a 4in lift, just took out the whole front end suspension. I'm putting everything back on and I'm putting the CURRECTLYNC Heavy-Duty Tie Rod System with the OEM pitman arm. My wheel is off and I can't make the drag link shorter. Nothing is tighten down yet. Old owner had a drop pitman arm installed before, when I try using the the drop pitman arm it fits perfect, wheel is centered. So can someone tell me the exact procedure to get it straight?
