if I ever take my dash out I’ll be sure to do it. But don’t see my dash coming out anytime soon
you can fit some as best you can without removing the dash. I find the grommet for the steering shaft to be a vacuum line for heat when driving as well.
yes factory exhaust
If it hasn't been replaced, it could be the stock old one. Once I get the exhaust sorted out 100% i will also wrap the S pipe from the header down to the cat. There should still be plenty of radiant heat in the winter for the oil pan if needed.
