It will. Most of us drill a 1/8" hole in the top of the thermostat to make it bleed air quickly. There's a thread on it somewhere on here.
Thanks... so much more to learn.
Personally I put in six quarts when I change the oil without checking the dipstick unless I want to see what six looks like. Be sure you have six in. Some people starve at high angles but it's pretty extreme wheeling. Hopefully you were just a bit low.
The brown slush mud are the rusts particle that you need to worry about.Coolant issue:
But my coolant was like brown sludge mud.
Being your first time out, did you air down? I find that being aired down on the trails makes it easier to drive/not stall, especially when you aren't used to driving offroad.
Those are a good sign to flush your cooling system. Flush it thoroughly with that chemical to remove the rusts.
Next time you are out in the woods, practice: Be mindful about the RPM / MPH / 4Lo & 4Hi. It is all related to a manual trans bec. you the driver needs to understand how the engine works at a certain RPM.
Edit:
