Preface- I recently rebuilt and re-geared my Dana 30 (open diff) so all the gears, bearings, cups and seals are new. I'm now installing a front locker and 30 spline axle shafts which means I need to ensure the gear set up is correct (back lash and contact pattern). I'm re-using the 4:88 gears and pinion because they are only a few months old.
I need to know if I should replace the bearing and cup on the "yoke" side of the pinion shaft if for some reason I have to change the pinion depth. I remember that bearing has a slight interference fit and is pushed onto the pinion shaft when you torque the yoke nut down, but I'm just not sure if it's re-usable. I've probably put 500 miles on it so its pretty new. I do have a new yoke nut and crush sleeve coming in for the install.
Thanks!
Thanks!
