Hi guys, I have been doing a bunch of reading and greatly appreciate this forum, it would be reassuring to get a bit of feedback on my first ever coolant flush plan just to make sure I have assembled the information in this forum correctly for my situation. This is a new to me 2004 4.0 TJ with 90K miles, previous owner just replaced radiator with cheap aftermarket and is leaking, I believe all other cooling system parts to be original.
I plan on replacing most all cooling parts, in hand - radiator, radiator hoses, thermostat and gasket, water pump, fan clutch, heater hoses, new radiator cap, 2 gallons zerex GO5, auxillary belt, temp sensor (thanks for forum list).
Flush plan, prior to replacing any parts:
1) Drain radiator at petcock and drain block at block plug.
3) Remove overflow tank and clean.
4) Fill system with distilled water and Prestone “flush+cleaner”.
6) Drain radiator and block like above, and refill system with only distilled water
7) Run car up to temp for an hour, let cool.
8) Repeat #6 and #7 until drained distilled water is clean (if things look really nasty maybe start at #4 again and leave the prestone “flush+cleaner “ in for several hours of driving…….).
9) Drain radiator and block like above
10) Replace parts and fill with coolant 50/50.
11) check for leaks.
Thanks,
Scott
- Does this purge all coolant?
- Instructions say something about just draining radiator and refilling with “flush+cleaner” and topping off with coolant (?). Any issue just using all distilled water and prestone “flush +cleaner” or does the “flush+cleaner” need coolant in the system for some reason to work?
- Will I be able to refill radiator and block through radiator cap or do I need to remove the temp sensor to fill block?
Thanks,
Scott
