What's your Warn winch and why?
Irun
A vicious cycle of doing, undoing, and re-doing!
Virginia
I'm planning to add a winch to my trailer. Although it will be serious overkill, I'm going to use this as an opportunity to move my existing heavier Superwinch, EPi9, to the trailer and pick up a new Warn for the Jeep. A primary factor for doing this is weight savings, reliability (the Superwinch has been ultra relaible, but is now 7 years old), and future parts availability.
Given my last winch was an M8000, which I stupidly gave to my Son, who then sold the Jeep with it on there, I'm using that as my benchmark. My current EPi9 weighs in at around 80lbs, with synthetic line and a Hawse fairlead. Warn shows the updated M8, with synthetic, weighing in at 55lbs.
I've also been looking at the Zeon series, both standard and platinum. I'm not opposed to them, but they're more expensive and heavier. On the plus side, they're more weather resitance and have faster line speeds.
For what it's worth I do recognize there are other choices out there. However, the fact that you can still get parts for something like a 1974 8274 says a lot about a companies commitment to their customers and products. In today's crazy world, I'll take a little stability and normalcy. All that said, I'm curious what Warn winch you run and why?
9.5XP-S - low profile, light weight, relocatable control box, high line speed, power
Reactions: Irun
8274 PERIOD is my thoughts on a winch. I've had one on a Jeep since the 80's. From my CJ5 I had to a YJ and then now on my TJ. If you watch you can buy a used one for $200-500 and then rebuild it for another $400 or less.
I'm rebuilding my current 8274 but am going with improved parts so it will cost me about $600 to rebuild it but I bought it for $250. By putting a higher HP motor on one and a few other items it will match or exceed the currently offered new model 8274. And they ain't cheap either.
I have a old Ramsey low profile winch I've been planning on putting on my trailer.
Reactions: derekmac and LJGreg
I run an 8274 because I consider it one of the best and most reliable (mine is still using the original 1985 motor) winches you can buy, and you can't beat the speed! It is a heavy SOB though!! lol
You got it, but considering the speed and storing 150 of cable outweighs the weight factor imho
I went with the Zeon 12-S. It’s strong enough to recover a significantly larger vehicle and even to use for yard work, and comes with synthetic rope. I relocated the control pack under the hood to make it lower profile and maximize airflow to the radiator.
I had an 8274 on my FJ40, back in the 90's, for almost a decade. I'd love to have one for sentimental reasons, but the weight makes it a non-starter for me. They are amazing winches though!
I really like the simplicity of this setup. I'm assuming this is 3/8" line, so how much line do you have on there?
85'. 100' is too much, especially if one is doing a side pull and the line is bunching on one side. Better to use a winch line extension when a really long line is necessary than too much line on the drum.
VR8000. I wouldn't suggest it. One thing, Warn has been having periodic 10 percent off sales recently. Might want to wait for the next one. Seems to be every couple months or so.
Reactions: Irun
This is why I asked. Warn says they ship with 100", but everything I read says install 85'. I'm guessing due to line bunching up on the supporting rods?
Out of curiosity, what would you consider a good deal on very lightly used Zeon 8 (Steel cable)? I have a buddy who has one and he's selling his Jeep. He told me to make him an offer, but I don't know what would be reasonable?
I paid $450 for the Zeon 8-S on my LJ. It was a ornament on a JK headed for trade-in. I have a M12000 on the Ram 2500 because it came with the truck. :D
  • Wow
Reactions: Irun
