Hey yall, I may have a problem but not sure. I am installing an aussie locker,, SO when i put the carrier into the bench vice to remove the ring gear bolts everything went very well. BUT when I took the carrier out of the bench vice and set the carrier on my table top , I looked over on the vice and there set the skeleton frame that holds the roller bearings and the roller bearings. They actually cam off the end of the carrier. SO I carefully put the skeleton frame with the roller bearings on the table top and now I guess i will just put the bearing race back on it when i install the chunk back into the deferential housing. I dont think the bearings should have come off that easy but they did. how does that sound
