By better take-off do you mean better performance from a stop?
yes. Acceleration. I have 4.56 gears.
https://www.shop.blackmagicbrakes.com/Nutsert-Kits-03-06-Jeep-TJ_c108.htmhttps://www.jeepforum.com/forum/f140/nutsert-removal-install-598868/Back to @Hog 's lake house for another episode of " Adventures with Rivnuts" due to a spinner in his wife's nice LJ's skid plate we couldn't resolve Saturday.
First , as a note , my inspection camera showed this rivnut was never crushed - it may be the case these that tend spin aren't set properly at the factory.
We found a steel replacement Rivnut, but getting it to pull down tight without spinning proved to be the challenge since we couldn't reach in the frame and these had no flare for a serrated nut to grab like in Blaine's design , so we got creative and found a way to make one bite I felt was worth sharing -
We left the new rivnut hanging out of the frame 3/16-1/4" and sliced it vertically with a grinder cut off blade 3-4 times so that what was hanging down would be tabs that easily fold outward - then we lifted the skid up and inserted the bolt and tightened it steadily- what happened was the sliced end splayed out as we hoped and got sandwiched between the frame and skid plate - this worked excellent as the more we tightened the bolt the more it squeezed the rivnut tabs we created, preventing the rivnut from spinning and this allowed us to apply the torque needed to flare the rivnut inside the frame. Basically we created tension with the outer side of the rivnut, opposite of its intended design, in order to get the torque needed to set it properly.
Rear shoes, hardware after fixing the PO hack of a brake job and front caliper pins and boots/brake service. Also repaired a dime size rust hole in drivers side of tub.
CHINA virus wasn't available.You misspelled CCP Virus.
Rear drum brakes are all the same. Jeeps are no different. The first thing I do on all of my vehicles when I buy them is replace front and rear brakes (rotors, drums, etc) and all hardware.How hard was that? I’ve done several drum brakes for other vehicles and this forum got me spooked on Jeeps.
Yes, I was indicating a serrated but won't grab a stock style insert with no flange, plus we didn't have one .. this is basically a hack but got it done.
The drum brakes on the TJs are no worse than any others. There are several videos out there on how to do them. It doesn't require any special tools (you can get one of those retainer clip tools if you want but they are not required) and usually takes about 45 min. a wheel, all told. I suggest getting a complete hardware kit along with the brake pads; that way, you can put all fresh parts and you won't have to worry about any bent or broken bits (clips, springs, etc.).How hard was that? I’ve done several drum brakes for other vehicles and this forum got me spooked on Jeeps.
Thank you Amazon for the cheaper than normal Morryde. Little bit of work with the Savvy tail lights but I think this looks better than cutting it out square to clear the light body.
Damn, that looks pro! Do you want to come down to Escondido and cut mine out when it comes in?
Thank you for the advice.plastidip is only Useful to conceal damage. I personally hate it.
to remedy faded black trim, I recommend SEM TRim paint. Others have success with other approaches but SEM is all I use.
Krylon Fusion works great on plastic parts like the fender flares.if I need to refresh some black parts on the jeep when should I use Bedliner and when should I use Plasti Dip?
I like my windows too much to ever lock my doors. I never leave anything of value in my Jeep.Finished installing the automatic door locks today. As I was doing it I set them up so that I can use both my half doors and full doors and have the locks work by installing a 2nd set in the half doors.
