I recently started greasing my own zerk fittings on my 2005 TJ. I found out from my mechanic that they had been using a pretty generic lithium grease (red) and the first time I did it I used my friends grease gun who had Valvoline high temperature lithium (red) grease which I figured would be fine. Now I want to buy my own gun and want to use Lucas Heavy Duty non-lithium grease (green). I have read that mixing the two can cause them to liquify or cause issues. Anyone know if this is true? Do I have to stick with lithium from now on? Or will I be ok making the switch and I'm overthinking it?
Links below:
Current grease:
https://www.amazon.com/gp/product/B000CQ4DIM/?tag=wranglerorg-20
Want to change to this:
https://www.amazon.com/Lucas-Oil-Ounce-10301-Grease/dp/B000IG20RW
Links below:
Current grease:
