I've done searches on this, and don't really see a definitive answer...
I'll keep it short: Next year, I'm going to install the H&R springs, either Rancho or Bilstein shocks, and 31x10.5R15 tires on stock wheels. I also want to refresh the suspension components.
I "assume" that stock spec suspension components are all I need with the H&R springs...
I "think" I need upper and lower control arms, along with new swaybar links - front and rear. Swaybar bushings have already been replaced. Steering "seems" to be fine, not planning on touching it at this time, but I'm getting clicking from the swaybar links at the very least.
1) I'm thinking Moog all around, but saw "Detroit Axle" on Amazon. Good, bad, indifferent? Other makes I could/should consider?
2) Should I be looking at anything else? What about bump stops with the H&R springs? Stock OK, or no?
3) Good source for replacement bolts if I need them?
