I'm really new to owning a Jeep so I'm not sure what is causing this noise.
Slowing down usually kicks it off.
It will start with a pop and then it will start whining. The popping will happen randomly and engaging the brakes do not stop the sound.
The whining is consistent with the speed and will normally go away if I stop but then will continue some time later.
There are times that it doesn't make any noise.
Doing a little research on this forum, I'm thinking it's the ujoint in the front axle. If I do replace the ujoints on both sides are there things I should just go ahead and replace since there is a decent amount of work just to get to the ujoint?
