New here. So I’m rebuilding a 2000 TJ with My Son. I was wondering after installing a 4” suspension lift, if I would be able to fit 35x12.50 on a 16x8 rim without any rubbing. Any other suggestions would be greatly appreciated.
Not gonna be doing any off-road. More for My son when it’s done. Not sure what bump stops are. I’ll be changing the front and rear bumpers also. Not sure if that makes a differenceWith bump stops, you can get away with it.. Assuming the backspacing on the wheels is good. Preferably you'd want an extra 1"-1.25" for off-road use
You may want to read this link from the forum.New here. So I’m rebuilding a 2000 TJ with My Son. I was wondering after installing a 4” suspension lift, if I would be able to fit 35x12.50 on a 16x8 rim without any rubbing. Any other suggestions would be greatly appreciated.
Bump stops are not related to bumpers. New bumpers are a cool upgrade.Not gonna be doing any off-road. More for My son when it’s done. Not sure what bump stops are. I’ll be changing the front and rear bumpers also. Not sure if that makes a difference
Have you ever seen a 1996 TJ or wrangler?The 96-06 TJ were not built quite that way.
I have, but I was drunk ha.Have you ever seen a 1996 TJ or wrangler?![]()
I like the tires!! Brand and specs please! Thanks
Yup, just do a 2 inch lift with 33s. All the look of an off roader without being an off roader. Exactly what a jeep was meant for....
got me too.......... maybe 2" lift and a BL to get the rest.If street performance is a concern, 2" of lift isn't enough for 33s.
Procomp 15x8 wheels and procomp 33'sI like the tires!! Brand and specs please! Thanks
