The guy who bought my TJ X had issues with the front seat belts flapping in the wind when he ran the Jeep with the upper half doors off. His solution was to put a half twist in the seat belt. Seems to have solved the problem, and it no longer gets caught between the door and the striker he says.View attachment 16561 I'm sure it's been done but put Velcro straps around back seat (removed) seat belts. No more flappin!
it's pretty straight forward, as most note the LED's are directional with no way easy eat to tell what the polls, so it's trial and error just don't bolt everything on before testing as there is a good chance you will need to flip some of them 180 degreesI have those same blue LEDs for my dash. Is it an easy install? Any tricks or cautions?
Lee - 2005 TJ 4.0 Auto - Las Vegas
Ditto lolI have them as well. Easy install. But because of the nature of LED's polarity they will only work when inserted a certain direction. After installing the dash lights I had to get the hvac lights too.
https://www.amazon.com/dp/B0146AMD4U/?tag=wranglerorg-20
Tried to install my Currie rear shock mount adapter, but the hole on the mount was smaller than the bolt..
Need to give them a call tomorrow..View attachment 16578
Where did you get the bulbs from? ThanksView attachment 16422 Changed my cluster bulbs to blue dimmable LED's. it was still daytime but it looks a lot brighter when it's dark
I use the same thing for mine. The flapping was annoying.View attachment 16561 I'm sure it's been done but put Velcro straps around back seat (removed) seat belts. No more flappin!
I ended up just buckling mine.View attachment 16561 I'm sure it's been done but put Velcro straps around back seat (removed) seat belts. No more flappin!
Fun little obstacle. Looks a lot worse than it really is, but it definitely gets the heart pumping.View attachment 16583 Successfully ran it up hells gate at Moab!
Driving skills??? HeheheHow did you not do this before the SYE? Shock damage?
Awesome! We hit Moab rim today and headed to poison spider tomorrow.We are in Moab right now as well. That's one hell of a trail, congrats!!
Ebay seller called robbier33Where did you get the bulbs from? Thanks
