Man the weather SUCKED this weekend. Didn't get nearly as much done as I wanted.
Interior:
Got the center console ripped out and removed the shifter assemblies for both the trans and transfer case. The rubicrawler is out and packaged up, waiting for the same guy that bought the engine/tranny to pay the balance. I started to work the Genright transmission cover plate, but ultimately pulled off for now. It was too damn cold to be banging on aluminum to fit the curve of the tunnel. I'll work on getting that shaped on a better weekend.
Also got the accelerator pedal pulled along with the cables for the trans and pedal. One item I'll have to contemplate is the ignition lock cable/solenoid. Not sure how that's going to work with the Winters shifter, but not sure if I'm going to throw more wrenches in the gears by removing it. We'll have to play with it later and see. For now, I disconnected the cable from the ignition cylinder and left it hanging.
Engine Bay:
I got the steering all disconnected in the bay. The OEM pillow block/bushing was thrashed pretty good. I'm going to have to do a little bit of grinding to get the new steering shaft in the Red Rock kit to fit into the clamp at the firewall. Also not entirely sure how they connect the shaft to the steering box, assume I'm going to have to grind/remove the u-joint coupler at the steering box end of the intermediate shaft. I'm assuming the book will inform me on this process, but we'll see. Still haven't heard back from Jim/Red Rock, which has been pretty par for the course unfortunately.
Northridge had a sale this weekend on PSC stuff, and knowing that my current steering box is getting sloppy, I pulled the trigger on their steering box with ram ports for future expansion. I also grabbed their hemi swap pump kit with remote resevoir. PSC notes you may need to shorten your steering shaft, so I figured I ought to get this now before I measure and chop the new red rock shaft.
Didn't get the engine mounts out yet, that'll be next when the weather clears up.
Started to look at which holes I'll need to plug in the firewall as well.
Fuel Tank:
The tank is now in it's new skid, nice and tucked away. I got the fuel pump installed, but the box didn't have a new screen filter. I put an email into Red Rock to see if there's supposed to be one, apparently it doesn't need it. Super straight forward though...pic for comparison.
The new pump in the kit was branded Autobest, which I'm not totally thrilled about. Definitely not the brand I would have gone with if I was picking a pump (bosch, delphi, denso), but I'll withhold judgement until I actually put it to use. I am also guessing they might have swapped the pump unit, I'm going to pull the lower cover and investigate, if nothing else to know what I need to replace it when it burns out.
Transmission:
With the weather absolute shit, I went back into the garage and worked on the transmission. I got the 2-4 clutch assembly put back together, and again cursed not owning a real lip seal tool. I got it done with feeler gauges, but damn it would have been easier with a true tool.
With everything put together, I went to assembling the case. I had completely stripped the case and sent it to be hot tanked with all the other trans parts/engine parts. With a little bit of elbow grease and multiple in-and-outs for each module, I got everything in the tunnel put together.
And found this...D'oh!
I forgot to put the shift arm/parking brake lever back in prior to starting...so everything goes back out and back in to get the shifter arm put in. I feel pretty confident in tearing a 545rfe apart and reassembling though! Only took 6 times...
Anyways, of course at the end I ended up tearing one of the scarf rings at the top of the input shaft...so won't be able to totally button this thing up until I get a couple replacement rings later this week. Make sure you fit those damn rings AGAIN prior to putting the pump on. I did get a chance to air check everything and it appears we're all good!
Weather looks crappy for the first half of this week, so I'm going to move some projects into the garage to keep going. I still need to put the finishing touches on the motor, specifically sensors, coils, spark plugs, etc. I'm also considering mounting the harness on there prior to picking and dropping in the frame. I've also got some smaller paint projects I can bring in and work on after work. Hopefully this coming weekend gets a little nicer.
