Build sheet question (lets see them build sheets)
jmbstudios
Guitar Slinger
ARIZONA
Looked up my build sheet.
Don't know anything about build sheets, except it's info about my ride.
Question is....
When you get down to the options list, is that what is available to have added or the options that were actually ordered and put on my jeep?
Thanks.
Post Your Build Sheet!
Vehicle Description 2004 JEEP WRANGLER X 4X4 SPORT UTILITY 2-DR
Monotone Paint
117 Amp Alternator
500 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
High Back Bucket Seats
Reclining Front Seats
Rear Folding Seat
Next Generation Front Air Bags**
Front Seat Area Carpet
Cargo Tie Down Loops
Sport Bar w/Full Padding
All 4-Speed Automatic Transmissions
Command-Trac Part Time 4WD System
Dana 30/186MM Front Axle
Dana M35/194MM Rear Axle
Tinted Windshield Glass
Rear View Day/Night Mirror
Swing-Away Mirrors
Route 39 - UP, Phoenix, AZ
Instrument Cluster w/Tach
100 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Single Low Note Horn
STANDARD EQUIPMENT
12V Auxiliary Power Outlet
Locking Glove Box
DARK SILVER METALLIC - Badge - X, c
DARK SILVER Metallic - Badge - Jeep,
DARK SILVER Metallic - Badge - Wrang
BLACK - FENDER FLARES
Halogen Headlamps
CHMSL Lamp
Black Front Bumper
Black Rear Bumper
Bumper Extensions
Chrome Headlamp Bezels
Black Front Frame Overlay
Body Color Grille
Trail Rated Badge
EVAP Control System
19 Gallon Fuel Tank
Bright Silver Metallic Clear Coat
AM/FM Compact Disc Radio w/Chgr Ctrl
4 Speakers
Power Steering
Steering Wheel
Normal Duty Suspension
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Outside Tire Carrier
P215/75R15 RBL Wrangler AT Tires
15X7.0 Full-Face Steel Wheels
Upgraded OBD-II Connectors
Fuel Tank Skid Plate Shield
Transfer Case Skid Plate Shield
Tethered Fuel Filler Cap
Protective Coating and Remover
Build To U.S. Mkt. Specifications
GVW Rating - 4450#
U.S. Dealer Retail
Zone 71-Los Angeles
TJ-Vehicle Family
Four Wheel Drive (4WD)/(4X4)
Left Hand Drive (LHD)
Short Wheel Base (SWB)
Vehicle Order Tracking
U.S. Specifications Label
Arizona Ship to State Code
Arizona Sold to State Code
Cloth High-Back Bucket Seats
Dark Slate Gray
Convenience Group
Mutually Exclusive Package
Easy Access Pass Tip & Slide Seat
Rear Seat/Wheelhouse/Cargo Carpet
Front Floor Mats
Full Length Floor Console
4-Spd. Automatic 42RLE Transmission
Lock-Up Torque Converter
3.73 Rear Axle Ratio
4.0L I6 Power Tech Engine
Light Tint Front Door Windows
Full Metal Doors w/Roll-up Windows
Tinted RR Qtr & Liftgate Windows
Rear Window Defroster
Air Conditioning
Rear Window Wiper/Washer
Courtesy Lamps
Underhood Lamp
50 State Emissions
Federal Tier 2, Bin 9A Emissions
All Radio Equipped Vehicles
Fixed Long Mast Antenna
Full Size Spare Tire
Goodyear Brand Tires
Black Hard Top
Matching Spare Wheel
All Steel Wheels
5 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: TJ TRACKING: 30603J04 MY:2004
FAM: TJ TRACKING: 30714J06 MY:2004
Customer Preferred Package 2TX
Customer Preferred Package 24X
Customer Preferred Discount
Paint Order Code
Pretty sure it’s the options that your particular Jeep was fitted with. I have a Dana 35 rear and nowhere on my build sheet is there mention of a Dana 44 if that makes sense.
Nice. Thanks.
My build sheet says I have a 19 gallon fuel tank. But options say 5 additional gallons of gas.
Yeah. I don't remember seeing 5 extra gallons going in at the pump.
I could be wrong, but I read that the stock tank is 14 gallon and a 19 gallon tank is an option. Which may explain the extra 5 gallon notation.
My build sheet says the same thing FWIW. I have a 19 gallon tank. And as others have mentioned you can't utilize the whole 19 gallons without doing the gas tank mod. There's a thread on the board for that mod.
Here you go. 04 Rubicon.
Vehicle Description 2004 JEEP WRANGLER RUBICON 4X4 SPORT UTILITY 2-DR
Convenience Group
Monotone Paint
Off Road Group
117 Amp Alternator
600 Amp Maintenance Free Battery
4-Wheel Disc Brakes
Rear Folding Seat
4:1 Rock-Trac HD Part Time 4WD Sys
Heavy Duty Dana 44 Front Axle
4.11 Rear Axle Ratio
Heavy Duty Dana 44 Rear Axle
Tru-Lok Front & Rear Axles
Swing-Away Mirrors
Route 99 - UP, Port Allen, LA
Locking Glove Box
DARK SILVER METALLIC - Badge - Rubi
EXTERIOR COMPONENT COLOR
Halogen Headlamps
Front Fog Lamps
CHMSL Lamp
Black Front Bumper
Black Rear Bumper
Bumper Extensions
Black Diamond Plate Sill Guards
Body Color Grille
Trail Rated Badge
EVAP Control System
19 Gallon Fuel Tank
Solar Yellow Clear Coat
4 Speakers
Power Steering
Steering Wheel
High Pressure Gas Charged Shocks
Rear Stabilizer Bar
LT245/75R16E BSW 31" MT/R Tires
16X8.0 "MOAB" Silver Wheels
2 Front & 1 Rear Tow Hooks
GVW Rating - 4600#
U.S. Dealer Retail Zone 63-Dallas
TJ-Vehicle Family
Louisiana Ship to State Code
Louisiana Sold to State Code
Dark Slate Gray
OPTIONAL EQUIPMENT
Front Floor Mats
All Manual Transmissions
5-Speed HD Manual Transmission
Air Conditioning
Shift Indicator Warning Lamp
Courtesy Lamps
Underhood Lamp
50 State Emissions
Black Easy Folding Soft Top
All Aluminum Wheels
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
FAM: TJ TRACKING: 30604J02 MY:2004
FAM: TJ TRACKING: 31001J09 MY:2004
Customer Preferred Package 2TU
Customer Preferred Package 25U
Paint Order Code
65th anniversary edition.
VIN 1J4FA39S36P752928
Vehicle Description 2006 JEEP WRANGLER X 4X4
STANDARD EQUIPMENT
* Convenience Group
* Monotone Paint
* 117 Amp Alternator
* 600 Amp Maintenance Free Battery
* High Back Bucket Seats
* Easy Access Driver Tip & Slide Seats
* Reclining Front Seats
* Rear Folding Seat
* Next Generation Front Air Bags**
* Front Seat Area Carpet
* Rear Seat/Wheelhouse/Cargo Carpet
* Cargo Tie Down Loops
* Sport Bar w/Full Padding
* All 4-Speed Automatic Transmissions
* Command-Trac Part Time 4WD System
* Dana 30/186MM Front Axle
* Tinted Windshield Glass
* Rear View Day/Night Mirror
* Swing-Away Mirrors
* Instrument Cluster w/Tach
* 100 MPH Primary Speedometer
* Var Intermittent Windshield Wipers
* Single Low Note Horn
Equipment Listing
1 07/09/21
* 12V Auxiliary Power Outlet
* Locking Glove Box
* Lt. Quartz - Badge - Jeep, Lower Cow
* Lt. Quartz - Badge - Wrangler
* EXTERIOR COMPONENT COLOR
* Halogen Headlamps
* CHMSL Lamp
* Black Front Bumper
* Black Rear Bumper
* Black Bumper End Caps
* Chrome Headlamp Bezels
* Black Front Frame Overlay
* Body Color Grille
* Trail Rated Badge
* EVAP Control System
* 19 Gallon Fuel Tank
* Jeep Green Met. Clear Coat
* AM/FM Compact Disc Radio w/Chgr Ctrl
* Power Steering
* Front Stabilizer Bar
* Tilt Steering Column
* Full Size Spare Tire
* Outside Tire Carrier
* Upgraded OBD-II Connectors
* Fuel Tank Skid Plate Shield
* Transfer Case Skid Plate Shield
* Tethered Fuel Filler Cap
* Protective Coating and Remover
* Build To U.S. Mkt. Specifications
2 07/09/21
* GVW Rating - 4450#
* U.S. Dealer Retail
* Zone 66-Orlando
* TJ-Vehicle Family
* Four Wheel Drive (4WD)/(4X4)
* Left Hand Drive (LHD)
* Price Class H
* No Cargo Box
* Short Wheel Base (SWB)
* Vehicle Order Tracking
* U.S. Specifications Label
* North Carolina Ship to State Code
* North Carolina Sold to State Code
OPTIONAL EQUIPMENT
* Two Tone Cloth Seats w/65th Logo
* Khaki
* Tire & Wheel Group - 30"
* Jeep 65th Anniversary Edition
* Brake and Traction Group
* Smoker's Group
* Mutually Exclusive Package
* 4-Wheel Disc Brakes
* Easy Access Pass Tip & Slide Seat
* Floor Mats w/65th Anniversary Logo
* Full Length Floor Console
* Removable Ash Tray
* 4-Spd. Automatic 42RLE Transmission
* Lock-Up Torque Converter
3 07/09/21
* 3.73 Rear Axle Ratio
* Heavy Duty Dana 44 Rear Axle
* Trac-Lok Differential Rear Axle
* 4.0L I6 Power Tech Engine
* Light Tint Front Door Windows
* Deep Tint Sunscreen Windows
* Full Metal Doors w/Roll-up Windows
* Sunrider Soft Top
* Air Conditioning
* Silver Center Stack Bezel
* Cigar Lighter
* Courtesy Lamps
* Underhood Lamp
* Front Fog Lamps
* Jeep 65TH Anniversary Edition Badge
* 50 State Emissions
* Federal Tier 2, Bin 9A Emissions
* Speed Control
* Next Generation Engine Controller
* All Radio Equipped Vehicles
* 7 Speakers Inc Subwoofer/Tweeters
* Fixed Long Mast Antenna
* Sirius Satellite Radio
* Leather Wrapped Steering Wheel
* High Pressure Gas Charged Shocks
* Rear Stabilizer Bar
* 30X9.50R15LTB Wrangler OWL A/T Tires
* Goodyear Brand Tires
4 07/09/21
* Dark Khaki Soft Top
* 15X8.0 Forged Aluminum Wheels
* Matching Spare Wheel
* All Aluminum Wheels
* 2 Front & 1 Rear Tow Hooks
* Call SIRIUS to Activate@888-539-7474
* 1-Year Service Provided by SIRIUS
* Manuf Statement of Origin
* 3.2 Additional Gallons of Gas
* Spring - Left Rear
* Spring - Left Front
* Spring - Right Rear
* Spring - Right Front
* FAM: TJ TRACKING: 50916T04 MY:2006
* FAM:TJ TRACKING: 51216T16 MY:2006
* Customer Preferred Package 2TX
* Customer Preferred Package 24X
* No Charge Sunrider Soft Top
* Paint Order Code
5 07/09/21
I'll play.... Here's my 4.0 SE
VIN 1J4FA29S16P702359
Vehicle Description 2006 JEEP WRANGLER SE 4X4
Monotone Paint
Rear Folding Seat
Floor Console w/Cupholder
Swing-Away Mirrors
STANDARD EQUIPMENT
Locking Glove Box
Med. KHAKI SOLID - Fender Flares
Halogen Headlamps
CHMSL Lamp
Black Front Bumper
Black Rear Bumper
Body Color Grille
Trail Rated Badge
EVAP Control System
19 Gallon Fuel Tank
Deep Beryl Green Pearl Coat
4 Speakers
Power Steering
Steering Wheel
GVW Rating - 4450#
U.S. Dealer Retail
Zone 71-Los Angeles
TJ-Vehicle Family
Price Class L
No Cargo Box
Khaki
117 Amp Alternator
OPTIONAL EQUIPMENT
Air Conditioning
50 State Emissions
Rear Stabilizer Bar
Dark Khaki Soft Top
All Steel Wheels
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Customer Preferred Package 2TN
Customer Preferred Package 24N
Paint Order Code
