What gear ratio and transmission do you have?
The @ sign will signal Jerry... Do whatever he says... Even if it means running down the street in your underwear. It will work.Ok thanks for the thoughts. I'm not sure what to do.
@Jerry Bransford we've got a live one... Tell him to wear them on his head and post pictures.That sounds good. Thanks
Bob knows the Rabbit hole can have things other than Rabbits.Stick with the 31's. Trust me on this.
Good post.To do 33's properly it's going to cost you, probably more than you think. Even the cheaper ways can add up fairly quick. I suggest plenty of figuring, Mainly about the jeep and what your main focus with it will be..
Shocks look a little light morel like 500 +/-Bob knows the Rabbit hole can have things other than Rabbits.
I have 2 Rubicons...I have an 06 on 2" of lift and 31.5 inch tires more or less and an 03 on 33's and 3.5" when the hard top is on ...what it takes to run 33's well is way more than the 31.5's.
33's-
Tires- 1000.00
Gears 1750.00
Track bars 500.00
Control Arms - 800
Shocks 200
Sway bar links 260.00
31.5 -
Tires -1000.00
Shocks 200.00
That's it. I did a few things because I wanted to , like jks sway bar links, but running 31's is sane...i still think that had been figured out when the Rubicon was released, and influenced the 31" tire size they chose .....That's Andy talking, not a hard fact.
| Ball Joints Dana Spicer | 130 |
| 2 Tires | 342 |
| Console | 50 |
| Artec Lower Control Arm Brackets . | 75 |
| Apoc Adj Control Arms . | 650 |
| Unit Bearing and U Joints . | 180 |
| Ball Joint Tools . | 89 |
| rear sway bar Extreme Terrain Outfitters Order # 14-23401835 . | 204 |
| Axle Seals 4W Parts | 27 |
| coil Springs and Shocks . | 900 |
| Johnny Joints Upper | 212 |
| Brake Dust Shields . | 44 |
| Unit Bearing Bolts . | 27.81 |
| 39 tooth Speedometer Gear . | 22 |
| Paint and Sand Blasting | 120 |
| JKS Bushings for front quick detach sway bar link . | 27 |
| Sway Bar Bushings and Brackets . | 46 |
| Tie Rod Ends . Rugged Ridge | 180 |
| Cam Bolts . | 31 |
| Front BumperBestop HighRock 4x4 Front Bumper with 2' Approach Roller and Tubular Grill Guard | 200 |
| Nerf bars | 100 |
| Novak transfer case shifter . | 170 |
| Energy Suspension Bump Stops | 70 |
| Rear Axle Seals and Bearings | 100 |
| Front and Rear disc brake Pads and Rotors and Parking Brake Shoes | 330 |
| Misc Metric Hardware | 30 |
| Royal Purple 17/140 rearened Oil | 75 |
| Front Diff Ring and Pinion rebuild | 450 |
| mirror reloaction brakets | 25 |
| Parking Brake Boot | 15 |
| Driveshaft . | 300 |
Those are all realities.Shocks look a little light morel like 500 +/-
Lockers add another 1500 plus
Alignment 100 plus if you don't need any ball joints ect
Swing away tire carrier bumper cause your gonna need one 500-1200 for the bigger tire
HD tie rods and drag link
5 Tires probably 1000 to 1500 mounted and balanced includes spare
We are all married. As far as listing it on here, we spent $10.here is what I spent and my jeep already had the HD Draglink and Track Bar some of these items may not apply to your set up
This is parts only I did all the labor
Ball Joints Dana Spicer 1302 Tires 342Console 50Artec Lower Control Arm Brackets . 75Apoc Adj Control Arms . 650Unit Bearing and U Joints . 180Ball Joint Tools . 89rear sway bar Extreme Terrain Outfitters Order # 14-23401835 . 204Axle Seals 4W Parts 27coil Springs and Shocks . 900Johnny Joints Upper 212Brake Dust Shields . 44Unit Bearing Bolts . 27.8139 tooth Speedometer Gear . 22Paint and Sand Blasting 120JKS Bushings for front quick detach sway bar link . 27Sway Bar Bushings and Brackets . 46Tie Rod Ends . Rugged Ridge 180Cam Bolts . 31Front BumperBestop HighRock 4x4 Front Bumper with 2' Approach Roller and Tubular Grill Guard 200Nerf bars 100Novak transfer case shifter . 170Energy Suspension Bump Stops 70Rear Axle Seals and Bearings 100Front and Rear disc brake Pads and Rotors and Parking Brake Shoes 330Misc Metric Hardware 30Royal Purple 17/140 rearened Oil 75Front Diff Ring and Pinion rebuild 450mirror reloaction brakets 25Parking Brake Boot 15Driveshaft . 300
