So here’s my update so far.. brand new tires made a huge difference, I’d say 70% better driving it home was the first time I could actually use one hand to drive down the highway.
It still was a pretty rough ride but after playing with the tire pressure the most of the stiffness went away, my caster Is at 4.8 degrees with no more adjustment, next step is going to be upper and lower control arms so I can get to that 6-7 degrees. I’m gonna do them myself, since I found a set of Apoc online upper and lower for $299.00 4wp wants $450 just for the uppers unless someone knows something about that brand that I should stay away from??
Not sure about other 4wp stores but the one here in reno, are pretty much salesmen, when I asked about the stiffness of the ride the wanted me to buy new shocks :-/ I tried to explain there brand new bilsten 5100 put on by the p.o they said something like there not set up properly and need the 5125. From what I can find online the 5100 are fine for my ride, unless someone knows something different ?? I’m sticking with them. By the way they almost had every tire at a different psi 50,45,40,40..
It does have a shake but not real noticeable until I’m about 50-55 mph I’m thinking maybe driveline, pinion angle, really not sure does anyone have suggestions?
The steering still feels a bit loose but way better, I’ve been reading and some guys recommend new bushings, I’m all for that but does anyone have a suggestion on which bushings to start replacing or is there a kit of some kind?? All and all I’m pretty happy with the jeep.
Like I said before it’s my first jeep so I really don’t have anything to compare it to, but I think once I finish dialing it all in, I’d feel pretty comfortable driving it down to Baja pulling my jeep trailer🏖
Any thoughts or suggestions, super appreciated.... thanks
