That's really good to know. Thanks bud K&N or do you recommend another?Most everyone here will tell you that just running a quality filter in your stock air cleaner housing is the best you can do. There really isn't any advantage to running a Cold Air Intake as they really don't bring in any colder air and many time raise the intake air temps,
I see they do a performance air intake system. Is that the same as the cold intake systems I see around?
Thanks heaps man. They were both interesting reads. Happy I joined up here with you fellas now.
Also I would love to put a V8 in Tj but it's. Around 30 to 35k to do that here.
The best upgrade to your air intake is to remove the stock one, then put it back on with a clean filter in it. 5 HP increase guaranteed.Hey fellas I'm hoping to upgrade my air intake as my tj is still running the stock intake.
Any recommendations on best ones on the market?
Can I get the super chip Chris mod link? Only if you don't block my actual opinion.
You could or couldn't care less?As long as you don’t turn it political I could care less.
Hey now, I’m supposed to be the one correcting people’s grammar around hereYou could or couldn't care less?
The K&N actually filters WORSE when kept clean and oiled. It goes from bad to worse after be cleaned and oiled.Even in particular applications (older classics) where K&N has dyno’ed as adding one or two hp, the day-to-day reality is that not many people will clean and re-oil their filters on the recommended schedule. Maintaining a K&N is a pita compared to drop-in standard disposable filters.
Check out the chart in post #11 above and see if you still want to run that K&N.I never knew this. I put in a K&N last year and I just cleaned it a week ago. Now my brain I thought since I spend most of my weekends out in the Florida Everglades or at the beach areas it would be better.
