It started with a bad vibration that I thought was just misalignment. I had some issues getting my axles squared due to some other work I did, but since came out on top. I heard a grinding noise that sounded like it was coming from the front driveshaft so I replaced the centering yoke and the u-joints....no change. I still had the damn vibration so I took the rear shaft apart and replaced a well worn out u-joint that got rid of most of the vibration, but still had this terrible grinding noise that sounded like gears and picked up with speed. So, I then took the rear DS off and drove around, all vibrations were gone! My centering ball did not have a spring and I'm not too sure if it was supposed to have needle bearings in it? There were a few loose needle bearings in it when I replaced the u-joint, so I'm inclined to think it should.
Here's my issue now. I don't like this damn flange on the SYE the PO had put on. The driveshaft would probably go back together and work well if I replace the centering yoke and H-collar, but I hate fighting this flange and I completely stripped the hell out of one particular bolt and really don't want to mess with that again. In your experience, would it be better to just suck it up and get a different drive shaft? I want to move up to Metalcloak 4.5" springs and am currently sitting on 4" Rancho's I believe (PO had put on). I know I would need to get a different yoke to make a new shaft work.
Is it worth the trouble to get rid of the flange and move to a simple yoke on the SYE? Can I simply just get the right yoke with splines and bolt it down after I take the flange off?
