What MML with Savvy 1.25" body lift?
Robert Snider
Gibson, Ga
Want to put Savvy 1.25" body lift on. Already have 4 in suspension lift. What 1" motor lift should I use and will I have to adjust any linkages. Just installed 35's and need a little more clearance.
Just use these spacers:
https://savvyoffroad.com/product/sav-mmltj/
You'll have to adjust your transfer case linkages most likely, so I suggest going with the Savvy transfer case shifter:
https://www.amazon.com/dp/B073L4L4R5/?tag=wranglerorg-20
Chris my jeep is the 2004 Rubicon and its says this linkage dosent work on the Rubicon. Not sure what the difference is but guessing different transfer case?
The only Rough Country part that I have on my Jeep is the motor mount lift.
Reactions: TheBoogieman
I put M.O.R.E. raised motor mounts on mine and noticed a significant increase in vibrations. Made me wish I had gone with spacers instead of new mounts. I don't know if they are broken in now or if I just got used to the vibrations, but I don't notice it anymore.
Reactions: Sancho and JMT
FYI: I don't know if I just got unlucky or my mount is too soft, but my Savvy passenger-side spacer hits one of the bolts that holds the mount to the block and makes noise over bumps/washboards. Photo here.
It's on my winter wrenching list to cut that corner off and install new mounts, hoping to get to it in the next couple of weeks.
@Nep1303, the basic issue is vibration damping between the engine and the frame. The stock motor mounts do a very good job, so why take that away to substitute for something that may not do as good a job? A spacer is just that, a spacer that the stock mounts are mounted on top of. As long as your stock mounts are good I see no reason to change. Lis Automotive sells an Aluminum T6-6061 one for about $50. I used it in a rig. Problem free for a year or more now.
1" Motor Mount Lift (fits) 1987-2006 Jeep Wrangler YJ TJ LJ https://www.amazon.com/dp/B08HSGKJRF/?tag=wranglerorg-20
@Nep1303, the basic issue is vibration damping between the engine and the frame. The stock motor mounts do a very good job, so why take that away to substitute for something that may not do as good a job? A spacer is just that, a spacer that the stock mounts are mounted on top of. As long as your stock mounts are good I see no reason to change. Rough Country sells an Aluminum T6061 one for about $45. I used it in a rig. Problem free for a year or more now.
Thanks for the response, you just saved me $100
Reactions: Jamesval035
