TJ is misfiring worse after replacing distributor
Keith J. Mundil
Lincoln, Ne
I’ve been having problems with the jeep running rough and bouncing rpms while warming up after replacing the crank and cam shaft position sensors. Took it to a certified mechanic and they said it a problem with the distributor, so I figured I’d replace the whole thing.
I placed the crank to the 0 mark after cylinder 1 compression stroke and dropped the distributor in where it’s seems dead center of 1 on the cap.
Rough to start but went to drive it starts acting up at 2000 rpms and the flashing CEL pops up. Took it straight to autozone. Misfire in cylinders 1 and 4 and random misfires.
A little more information would HELP. What year? Engine? Transmission? Mileage?
What spark plugs are you running? Have you replaced spark plug wires? The distributor cap & rotor?
A duralast gold distributor is what I installed today.
The Factory service manuals provide a simple step by step procedure for distributor installation specific to your engine, I would go to the resource section and download the proper file and carefully review the process.
