Please help I have been without my daily driver AKA my 2006 65th anniversary edition Wrangler for almost a week now. I have tried everything I can think of and going on YouTube and these forms looking for the fix but no luck yet so I'm hoping someone on here can help? Here is the situation:
I have a 2006 Wrangler TJ 65th anniversary edition manual transmission with a hundred and seventy thousand miles on it. I was driving to a friend's house and waiting at a stoplight, after it went green I press on the accelerator and it stalled I thought maybe I let off the clutch too early so tried starting it back up a couple times and eventually started and was able to sputter off to the side of the road but then eventually died again and has not started back up since. I thought maybe the battery or the starter. When I charge the battery fully then try to start it the voltage drops way down. It will crank and crank and crank but no start. Someone suggested that it sounded like it wasn't getting fuel but then when I put the key in the run position I could hear the fuel pump priming. I tried spraying starter fluid in the intake but still could not get it to start. Also when I try to crank it, the rpm gauge doesn't move. I know from my past wranglers that this was a sign of a bad crankshaft positioning sensor so I bought a new one and switched that out and still no change. I checked what I believed to be all the grounds and clean them all and also checked all the fuses but they all were fine but still nothing.I'm at my Wit's end and I'm supposed to go back to work tomorrow and have no transportation. Any and all suggestions would be greatly appreciated.
Thanks,
Rob
Thanks,
Rob
