Unexplained coolant loss, no apparent leaks.
2001 TJ
181k miles
0331 head
Overheated recently, didn't boil over but lost a lot of coolant. Culprit was upper radiator hose that split at the bend near the A/C lines and valve cover. After it cooled, I discovered the split when I removed the hose to initially replace the thermostat. I ended up replacing both. (it was 6+ years old and it stays 1/16" open at room temp). New thermostat is a MotoRad/Stant 195 degree non "fail safe". Also replaced the Radiator cap (18 psi), pressure tested it recently and it is fine.
Prior to this, I over heated 3 years ago and replaced:
Original radiator with a new oem one (old one got a hairline crack by the cap).
Electronic fan motor (PO did it, I know the whole debate about fans
Until recently, there was no issues with coolant missing or leaking other than having to occasionally top of the reservoir.
*I have not needed to replace the heater core or water pump, although that can change.*
*In both instances, I never used any kind of sealer.*
Back to the issue.
The first week after I made the repairs I lost coolant, from full to add, within 60 miles going to work and back. Found a small leak on the clamp between the thermostat housing and upper radiator hose. Tightened clamp, leak stopped, and added more coolant. Next week, same about of coolant loss but no visible leaks. Jeep runs fine, no CEL, no oil pressure issues, no further overheating issues.
I am worried the cylinder head or head gasket could have failed. I do have the 0331 head. I haven't driven it since in case it is a head related problem. I've ordered some tools to help me diagnose the possible issue.
What I plan to do today is:
1) With a proper spill proof funnel, bleed the system of air again (there's a chance I didn't properly do it after I replaced the thermostat since I didn't have this funnel).
2) Do a combustion leak test with the blue liquid.
3) Blackstone labs oil test kit that I can take once the Jeep cools down a little (to see if coolant is mixed with the oil). I have full synthetic oil.
4) I will also pull the sparkplugs, inspect them and stick a bore scope camera into each cylinder.
Is this overkill or am I with in reason to do all these tests?
Do I need to add any pictures?
2001 TJ
181k miles
0331 head
Back to the issue.
