Turn signals not working while pushing on the brake
Brett
Indiana
so for the last year my turn signals have not been working on my 2000 TJ. The turn signals work perfectly fine until I put my foot on the break once the brake Is applied it acts like my hazards are on. I have replaced the relay and checked the fuse in the glove box but it still does not want to work. Any ideas?
Check and see if all the bulbs are the correct bulb, and they are installed correctly. I have had instances where the filament inside the bulb became unattached at one end, and attached itself to the other filament, causing a back feed in the circuit causing the symptom you are describing.
That sounds like an easy place to start. I will definitely look into that. Thanks!
