Defrost Vent Mesh Repair
98TxTJ
Near Denton, TX
Age and Texas sun has not been kind to the defroster vent mesh on my dash. More and more pieces of the grid mysteriously disappear and almost all are disconnected along one side.
Work had a roll of 1/2 inch plastic mesh that was going to be discarded. That'll work.
The original grid is molded into the dash piece. On the underneath side there is a bezel pinned in place with heat-welded studs. These were so brittle that all but one snapped off as I was figuring out how to get the bezel off.
I snapped off the remaining grid from the dash piece and cut a piece of the new mesh to fit, notching it around positions where the bezel had to be glued back in place.
I used hot melt glue to pin the new mesh down and then fix the bezel in place.
Done.
Great idea. Mopar no longer makes this part and most of the ones off used vehicles have been damaged as this vent mesh is pretty weak to begin with. Even mine is like this as well.
I will have to follow your lead.
Reactions: D M
It's funny this thread popped up, I was just given a khaki defroster cover that is in near perfect condition. Screen is perfect, even has the little metal clips on the back. If somebody wants it, we'll play ' pay it forward ' PM me and we'll figure it out.
99.9% sure that is not khaki for two reasons. They don't put the black reinforcement on the later ones and khaki is a later color. The second reason is the color is wrong for it to be khaki.
What color would you say that is?
Done.
Exactly what I needed!!! Thank you ~ great idea! I can't find that part anywhere! :)
Reactions: 98TxTJ
