The ram cover is good. I think @jjvw runs it.
I'm a big fan of the half cover like the warn as well. There are quite a few manufactures that sell them and I've abused the hell out of them. One build I did a few years ago was a Tj Rubicon on stock suspension, just skids. I wheeled the crap out of that thing for 2 years and the skids got abused like crazy trying to keep up to everyone with big lifts on 35+ tires.
Though not cheap, that's the one I'd go for. It's made from the stock Dana cover so its upper stock dimensions mean no interference with the steering and its ramped/beefed up lower half is well done and beefy as hell. I've run it and it's a great cover.
This is the one you want IMHO.
In my case, I still fill through the vent tube....
Good to know about the ram cover. That might be a good option for my rear axle next time I happen to have it off for a fluid change. How much higher is the plug? I wonder if it's enough to result in a good fill on an axle that's tilted back for a 4" lift, tuck and SYE on an LJ (which is similar to a 4" lifted but untucked TJ).
I called Currie they sent me to the builder,t&j and they are doing a run of Dana 44 covers now,they are not making the Dana 30 at this time,so I went with the thicker alloy hd Dana 30 cover and a guard on the bottomThough not cheap, that's the one I'd go for. It's made from the stock Dana cover so its upper stock dimensions mean no interference with the steering and its ramped/beefed up lower half is well done and beefy as hell. I've run it and it's a great cover.
Link?Anyone using the Rock Hard lower diff cover? Fits front and rear they say.
Oops!Link?
As far as I'm aware, that style half cover hasn't ever created a clearance issue. Stuff usually happens on the upper half.Oops!
https://www.rockhard4x4.com/product_p/rh-9053.htm
"OEM differential cover to face of HardHat™ at furthest point RH-9051 Dana 44 mounted HardHat: 3/8"
Naturally, I wonder if it will clear aftermarket track bars and if certain trackbars are engineered for better clearance? Like Rock Jock, for instance.
Front & rear Rock Hard for the price of one from T&J. Hmm..I ordered the Barnett/Currie one from T&J performance back in August and got it a few weeks ago. I believe they just did a run of them, it may be worth calling to ask for anyone in a rush.
As @jjvw said, the lower half usually isn't the issue - so you're likely fine. Though I don't anticipate needing anything that big for the rear as usually those contacts for me are low speed. Hitting the front with some momentum is more likely. Instead for the rear I have the RAM cover that's 3/16".Front & rear Rock Hard for the price of one from T&J. Hmm..
I like the stand off idea, no contact with the actual diff cover, other than the perimeter - but they're probably a good nest for rocks and other debris.
I have the lower half covers on my XJ and like them fine. I call them catcher's masks.
