B00mb00m
The Church of Cutting Brakes of Atlas-Front Digs
I swear we had a thread about this at one point but I cannot find it for the life of me. Now that the Atlas is taking shape I want to discuss two options:
- Steer brake handles with dedicated master cylinders: https://www.kartek.com/parts/empi-16-2543-34-bore-dual-angled-handle-steering-brake.html. Benefits are it looks cool and more handles. Downside, Blaine had mentioned previously its difficult to get high braking forces from the handle. It probably would work fine for loose dirt switchbacks that I will mainly use it for not necessarily bound up rock crawling digs. It would make running a factory console / ebrake very difficult. I don't want to give up my cable e-brake.
- Ball valves. This is actually the way I'm leaning. Planning to mount them between driver seat and door-sill. Double the cost of the handle operated one due to running one for each brake line. https://genright.com/products/ball-valve-parking-brake.html. I'd plan to run hard line to a T on top of Driver side frame run to two soft lines up to the handles, then 2 softlines back to frame, hard lines to upper control arm, soft lines to 2 L's on the axle. Should be able to reuse my axle side hard lines.
