Should I buy a used hard top?
Kathy
Manitowoc , wi
Hi, the jeep I just bought came with only a soft top. I plan on using my jeep during the winter. Do you think I need a hard top? Found this one on a used site around by me, wondering if it's worth it or if the soft top will due? I live in Wisconsin. Picture below. Thanks
The glass slider doors alone are more than $300.00 without the hardtop. Even needing minor repairs, this is a killer deal if you need a hardtop.
Come January you'll be glad you had it.
Reactions: Kathy
For $300 you can't go wrong. They're kind of a pain to install & remove but it's not bad with two strong adults. I managed to remove & replace mine on my back doing a turtle-walk but I wouldn't recommend it lol.
Reactions: Kathy
That's an awesome price, a steal actually! You'd be stupid not to buy it at that price.
I absolutely love my hard top. So much so, that I ditched my soft top in favor of it.
Jump on it. If you don't want it you can sell it for other upgrades ;) I paid $900 for mine last one.
Reactions: Kathy
So how do I operate the rear defrost it says it has?stupid question probably
And what are slider doors? Will the hard top make it quieter inside when on highway?
Now you're making things difficult ;). Odds are not good you'll get the rear defroster or wiper working. It takes a special wiring harness with a relay that I don't believe is sold any more. I bought my hard top later and had to buy the wiring harness separately to make it work, wiring it without that wiring harness kit wouldn't be easy. Not to mention the wiring kit includes a timer to shut the defroster off so it doesn't melt on the glass from being on too long.
Will I be ok without the rear defrost? My boyfriend is an electrician so maybe he could rig something. ? Also, the guy says he has a factory soft top with side doors. Are those side doors only for that factory soft top? I asked him and he said the material matches the factory soft top. I'm wondering if I'd want the half doors to use with my soft top or is it specific to the factory one?
The sliders doors are the upper parts to the half door.
And when I asked if the wiring harness was included he said it's all wired and included?
But he says that the glass slider doors are with the hardtop? Or am I mis understanding this?
If its a MOPAR hardtop the windows can't slide without heavy modification, more than likely its what I stated above.
The wiring harness is not THAT difficult and can be purchased/sourced with little difficulty.
So if I don't have half doors for my hard top the glass slider doors will do me no good? Will this hardtop work with my stock doors and windows? Here's a pic of the windows
View attachment 18121 View attachment 18122
This hardtop will work with factory hard doors, half doors and uppers, tube doors ect. The hardtop will not affect your door choice.
Reactions: Kathy
Curious — can you remove the back window of a hard top? Like you can with the soft top?
Not nearly as easily as a soft top. It can be removed yes, just requires a good socket set to pull the glass and hinge combo off the hard top and disconnecting the hardware for the defrost and the windshield wiper motor. Its not something that is usually seen as "worth it", but to each their own.
