I slowly pieced together my Super 35 kit with ARB RD105 and Revolution DC-Dana 35-30 axles, and Revolution gears. I got my locker installed and gears setup, but before I installed the axlt tube seals and bearings, I test fit the axle shafts. 1 shaft will not fit, but is 30 splines. The other fit fine, I tried the other shaft on both sides of the locker and it wouldn't fit the splines on either side. The bearings in the kit from Revolution felt a bit loose on the shaft that fit, unlike the OEM bearings (old worn bearings).
I measured the OD of the splines and was getting .010" larger on the one that wouldn't fit. No burrs, but I think it measured like 1.290", I do not remember the exact measurement. I've reached out to Revolution and will call them later, but honestly I don't know what I've got. The shafts look to be of good quality, but honestly I'm not sure if any of the axles are even correct, because I'm not even sure how to confirm the shafts are 1541, unless maybe 4340, 1541 or just OEM replacement axles have different hardnesses I can check or other dimensions.
The seal kit that was in the box read AK3599, which does not seem to correlate with the Dana 35.
I'll probably call Revolution later today, but I'm about to just order another kit from a more reputable vendor and run it and figure this set out for spare parts. I got it off Amazon, but I'm outside of the return policy. I only test fit 1 of the shafts when I got the kit and it fit, so I didn't think much else about it. Wasn't sure if anyone had any technical info that I can confirm what I've got.
