What do you guys think about outer axle seals?
They keep junk out but do they support the axle any while wheeling.
Are they worth the time?
Tossed mine in the trash.
You are correct.Correct me if im wrong please, but this would only refer to front axles right? From my understanding the rears have an outer seal only and no inner seal.
Those seals clearly work - that’s the cleanest front axle I’ve ever seen...
For all the reasons above...For the pennies they cost, why not?
Am I missing something ?
i think i imagine what you're saying? assuming i got this right, that would never work. soon as the passenger side wheel drops lower than the driver side, all you gear lube would drain into the long side of the axle?Why not just run the outer seals and do away with the inner seals. Easier to work on that way ?? The lube will be at same level...just like the rear end ?? Am I missing something ?
