Haven't checked that bud. And yes top hose is very hot.Thermostat stuck? Air bubble in system?
Have you checked any of those? When was the last time you changed the thermostat? Is the upper hose hot at all?
Again, what is your temperature gauge indicating? What temperature are you seeing that is making you believe your engine is running too hot?I
I will flush the radiator this weekend
What does the Temp gauge say? Can you post a pic of it while running "hot"I
A little more info than just its "hot" will help you get help.
Define running "hot".
What does the temp gauge say?
X4, what may seem to be too hot is often exactly how it should be. Tell us exactly what your temperature gauge is saying. 100c? 120c? 80c?
ApparentlyWhat does the Temp gauge say? Can you post a pic of it while running
